beogram 3500 and beomaster/beosound 5
This post has 13 Replies | 2 Followers
oggy1
Posts 14
Silver Member
oggy1 Posted: Mon, Apr 20 2020 12:28 PM
hi ,
I have purchased a beogram 3500 and would like to connect to my beosound /beomaster 5 and I cant see anywhere on the beomaster to accept any inputs
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi oggy1,
Welcome to BeoWorld!
please don’t worry if the link above shows as being out of stock, I will have more of these items arriving in the next couple of days. Please feel free to get in touch via my sponsor link below if you need any further help.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
oggy1
Posts 14
Silver Member
oggy1 replied on Tue, Apr 21 2020 9:58 AM
hi thanks for the reply,
was a bit worried about connecting the turntable as my system is a mess right now.
the usb ports are labelled service use only so I didn't think you could use.
will get one of those and then have a go at sorting out.
thanks
milliemissen
Posts 2,165
Thanks Oggy1,
The lowest USB port is labelled Service use only, the other two USB ports are available for use (only one can be used as an Aux input).
Please feel free to get in touch directly via the link below if you would like me to email you when the USB adapters come back into stock.  This cable will connect the Beogram to the USB adapter:-
https://soundsheavenly.com/beogram-record-players/14-2244-beogram-to-non-bo-device-phono-pre-amp-receiver-amplifier-etc.html#/2-length-1m/60-grounding-internal_ground_link
PS. Thanks MM for suggesting my link for the USB adapter Yes - thumbs up
Steve.
oggy1
Posts 14
Silver Member
oggy1 replied on Tue, Apr 21 2020 11:42 AM
hi steve
so when I purchase the device  and connect up then select the aux on the beosound 5 and also on the remote -which should turn on the speakers on all the masterlink system - I have beolab 3500 in kitchen and conservatory and  beolab 8000 in dinning room and beolab 6000 and 8000 in living room.
the living room doesn't work at the moment as just had new tv and is all out of sync. the tv is controlled with the new remote and I have the music controlled by beo remote 6 or beo remote 4.
the tv is a beo eclipse 55" andhas been installed by B&O but needs a delay box apparently.
many thanks for your help.
Posts 2,165
Hi Oggy1,
Yes, once you have the USB adapter and cable, please select A.Aux on the Beomaster 5 and then press Play on the Beogram to be able to access the turntable from any linked room.  The Beomaster 5 is not able to remotely control the Beogram, so you need to use the button on the Beogram to start the record playing.
Steve.
oggy1
Posts 14
Silver Member
oggy1 replied on Tue, Apr 21 2020 10:19 PM
hi steve
have sent you a request to let me know when you have the units in stock.
thanks
Posts 2,165
Thanks Oggy1,
I will let you know as soon as they arrive.
Steve.
Posts 2,165
Hi Oggy1,
Thanks for your patience, I am pleased to confirm that I have these items back in stock here: https://soundsheavenly.com/music-input/17-beomaster-5-beosound-5-aux-usb-input-converter-also-works-as-pcmac-sound-card.html
Please ask if you need any help finding the right cables to connect your products via this adapter.
Steve.
oggy1
Posts 14
Silver Member
oggy1 replied on Thu, Apr 23 2020 10:30 AM
morning steve
have purchased the adaptor and cables this morning - the one you advised earlier.
so will be waiting to try this out as soon as possible.
many thanks
oggy1
Posts 2,165
Thanks Oggy1,
I have posted these today!
Steve.
oggy1
Posts 14
Silver Member
oggy1 replied on Wed, Apr 29 2020 11:32 PM
hi steve
just wanted to say how grateful I am to you for sending the items which I have received today.
this is the first time that been playing around with the system even though had it for years.
the vinyl is playing through the system as you all said it would  and I am so pleased .
will be on this site all time now as its great with the info and would recommend you to everyone.
thanks again
Posts 2,165
Thanks Oggy1 Yes - thumbs up
Steve.
Page 1 of 1 (14 items) | RSS
