Shape: what is being dampened by the 'integrated noise dampers'?
This post has 12 Replies | 1 Follower
BeoFrederic
Posts 276
BeoFrederic Posted: Mon, Apr 20 2020 11:18 PM
Hello all:  what little I know about room effects on acoustics and speaker response*...I have always believed that acoustic dampeners should be placed on a) floor, b) side-walls, and c) ceiling.  This is because of the nature of the sound projected from directional speakers that are immediately in front of, or close to the 'front' wall.  Directional speaker sound is reflected from side walls and floor and ceiling, and secondarily from the rear wall if it's close enough to the listening position.
Yet a default Shape configuration includes 'integrated noise damper' tiles that, by virtue of their placement, must be dampening reflections on the *front* wall...where there are no reflections?  I'm confused.  Anyone?
*yes, I've read Geoff M.'s excellent blog post on the subject.
Millemissen
Flensborg, Denmark
Posts 14,680
Indeed there are reflections bouncing from wall to wall in a room........depending on your room, the room size etc.
The dampers are usefull.
However, if the rest of your room is bare and reflecting, the effect will be less noticeable.
Combining with ‘natural’ dampening - such as carpets on the floor, curtains, pictures, book on the walls....- must be the way to go.
How about another set of Shape with dampers only ;-))))
BeoFrederic
Posts 276
Thank you MM for your reply!
So, from what you wrote...while I'm there's some reflection from the front wall/behind the front speakers, my priority for managing room effects would be a throw rug and some books on the side walls.  That recommendation jibes with what I've read elsewhere.  And this sounds more affordable than a rig full of Shape dampeners Stick out tongue
More seriously, I'm a bit disappointed in B&O marketing -- and engineering -- on this point.
Emil Jensen
Denmark
Posts 766
I think that the number 1 purpose of the dampers are the possible to make a bigger system "Cheap"
It would be impossible to get a large system without it and still have proper space between the speakers.
That they also are dampers is merely a plus for sound generel not only the sound from the system.
The acoustics in new houses are terrible, with dry wall all over.
Millemissen
Flensborg, Denmark
Posts 14,680
A way to test this, is to compare the acoustic behaviour of the room before and after installing the Shape.....without music playing.
I know that this is hard......we very fast loose memory of how something sounds, when compairing.
However, I am quite sure that the Shape installation will help making the acoustics in the room ‘better, nicer’ just by being there.
matador43
Posts 1,373
matador43 replied on Wed, Apr 22 2020 11:42 AM
Emil Jensen:
I believe this too.
But is there a possibility for the dampener to work "sort of" like the foam inside cabinets? To pad the whole Shape structure own vibrations?
I mean by nature the tiles are also working as reflection screens, no? Diamond shape, clothe, plastic cradle with lot of details in there. Can't be worse then books on a shelf and certainly better than a bare concrete wall.
Geoff Martin
Struer, Denmark
Posts 672
The placement of an absorber in a room is (or perhaps "should be") determined by what you want to do.
If the problem you're trying to fix is a specular reflection from a side wall, then you should put the absorber at the point where the reflection occurs.
At my house, I have a problem with a specular reflection coming from the wall directly behind me when I'm sitting on the sofa (that wall is directly behind the sofa - so if I lean my head back, I will hit it). To reduce the comb filtering, I put a fuzzy pillow on the back of the sofa, behind my head. This not only fixes the (very local) acoustical problem, it also prevents me from hurting my head... (I tried getting one of the cats to sleep there, but they just won't stay put...)
However, if you're just trying to reduce reverberation time, then the absorption can go anywhere - because reverberation is random, both in space and time. (That's why bathrooms have more reverb on laundry day - the towels are out of the room.)
If you're trying to reduce modal problems, then a thin, fuzzy absorber (like the pillow behind my head in my living room) won't help because it doesn't absorb enough energy at low frequencies. There are better ways to do this (look up "membrane absorber" or "diaphragmatic absorber" -  which has to be designed to absorb a specific frequency.
So, the moral of the story is that there is no "best practice" for absorption placement. It's a tool that fixes a specific problem - and that problem, in some (but not all) cases, has a specific location.
Cheers
-g
OldJack
Split
Posts 371
OldJack replied on Wed, Apr 22 2020 3:26 PM
My listening room is acoustical disaster.Placing (canvas) paintings on the walls made great improvement.
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, Apr 22 2020 5:15 PM
OldJack:
Back in the day when I worked in audio sales, fabric printed wall hangings, the kind stretched over a frame, were popular. We used to take them and place acoustic tile in them behind the fabric, it was a good tuning/absorption thing that didn't look like acoustic tiles for people who had wives and such. Smile
Jeff
Barry Santini
New York
Posts 543
Geoff Martin:
Cheers -g
Q: When using room correction/optimizing software, should you:
1. Put room treatments in place and then use software to optimize, or
2. Use software to optimize and then point treatments in place as needed.
Barry
OldJack
Split
Posts 371
OldJack replied on Thu, Apr 23 2020 9:44 PM
Jeff:
Exactly
My SWMBO said:
1) Room decor improved
2) Everything sounds better now  Big Smile
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Thu, Apr 23 2020 10:38 PM
My painting of Elvis on black velvet did wonders for the acoustics in my listening room. Big Smile
Jeff
Geoff Martin
Struer, Denmark
Posts 672
Barry Santini:
Barry
Hi Barry,
#1 is the correct answer if your problem is comprised of room modes, and boundary effects (e.g. the bass boost caused by placing a loudspeaker too close to a wall or corner).
#2 is the correct answer if you have individual reflections from specific locations.
Cheers
-geoff
Page 1 of 1 (13 items) | RSS
