Long time fan of the site, first time poster here. I have a question regarding the third generation BeoPlay E8 true wireless earphones. I was wondering do any owners of the latest version of the E8 earphones know if they are compatible with either Comply's "Isolation" or "Comfort" series branded tips? Since Comply are currently running a "But One, Get One Free" promotion on their site, I was on Comply's website earlier to see which tips they mention are compatible with the recently released 3rd generation E8s in the hope of picking up some discount memory foam earths. The only tips mentioned as compatible with the third generation E8 earphones on their site are the "Sport Pro" eartips.
As the original E8 earphones and the E8 2.0 models are compatible with both the "Isolation" and "Comfort": tips as well as the "Sports Pro" versions (and the E8 third generation model sports a similar design to previous versions), I figured I would see if any users of this site are using eartips other than Comply's "Sport Pro" tips with their third generation E8 earphones. Any advice that can be given, would be greatly appreciated.
