I am trying to get Airplay to work with my Beocenter 2. I have connected 2 RCA plugs to Aux in on the socket box and have a small headphone jack into the Airport express. I have added A Aux to the Beo4 and chosen it on the TV Beovision 8 connected to the BC 2.
I cannot get any sound out of it. I have activated the Aux sockets on the BC 2 but still no sound.
The is obviously some other thing that needs doing of which I am unaware. Can anyone shed any light on what the problem may be?
(In another part of the house I have an Airport Express connected to an Avant and it works fine.)
I really hopw someone can shed some light.
Patrick
Hi Patrick,
you will have to activate the A.AUX-socket in the menu on the BC2.
Page 9 - Userguide.
EDIT: Sorry - you already had that done
Does radio/cd from BC2 work?
Greetings Millemissen
I have the exact same configuration as you mention. I am running Airport Express with no problems. Are you running masterlink? If you do, have you set the A.Opt. and V.opt. for the BV8 and the BC2? BC2 should be set to A.Opt. 0 and the BV8 should be V.Opt 2 (if your speakers are connected to the BV).
Best regards,
Frederik
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
