Beotime control over beoplay M5
This post has 5 Replies | 2 Followers
Gazfuller
Posts 32
Gazfuller Posted: Thu, Apr 23 2020 9:25 PM
I would like to switch on my beo play m5 using My Beo time  alarm  is this possible? If so can you instruct me please?
Razlaw
Posts 4,345
Razlaw replied on Fri, Apr 24 2020 1:28 AM
I don’t think it is possible. The Beotime uses the ir commands like a Beo 4. The M5 receives Bluetooth commands such as from an Essence Remote or BeoRemote 1 bluetooth.
laseralex
Posts 240
laseralex replied on Fri, Apr 24 2020 7:07 AM
Gazfuller:
There's no easy way to do this.  If you are good with software people have managed to make B&O IR decoders on Arduino and other platforms.  It should be possible to write code that receives the IR codes and converts them to BlueTooth commands on an Arduino or RaspberryPi.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! 🤦‍♂️
TWG
Posts 1,672
TWG replied on Fri, Apr 24 2020 7:07 AM
A lovely idea. IR control (Beotime, Beo 4...) for the newer Bang & Olufsen Bluetooth products.
You would need an infrared to bluetooth converter.
Those things were / are available e.g. from Logitech and RE-BL (there's a PUC from B&O for the RE-BL, too) to control the Sony Playstation 3.
1.) RE-BL: http://www.re-bl.com/ (only PS3 as far as I know)
2.) ir to Bluetooth for Playstation 4: https://www.amazon.com/PlayStation-Receiver-Logitech-Harmony-Control-4/dp/B01K3VMBM0#customerReviews
But the question is if it is pairable to a B&O Bluetooth speaker and how it reacts.
crossbytje
Posts 224
Isn't there an alarm function in the M5? I know there is in the M3.
This is not the answer to your question, but it may solve your problem..
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Apr 24 2020 9:06 AM
crossbytje:
Yes there is.
Page 1 of 1 (6 items) | RSS
