Beocenter 2 socket unit issue
This post has 3 Replies | 0 Followers
bigbruggsy
Posts 131
Silver Member
bigbruggsy Posted: Fri, Apr 24 2020 8:30 PM
Hello all, well Ive been able to get a socket unit to mate with my 2 beocenter 2 master units. Yes I have 2 master units now. long story................
With the help of beobuddy ive got both master units working well.
But when each are connected to my only socket unit sometimes I get a crackling sound through the speakers, its not straight away. If I play a cd or use aux in, maybe 30 minutes after playing fine I get this crackling sound. Its so bad that I have switch off the unit as im afraid it will damage my beolab1's.
Any ideas what it can be? Ive searched the forum but i havent found anyone else with this issue.
Beolab 8000 x 2
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound Ouverture
Beolit 12
bigbruggsy
Posts 131
Silver Member
Hi all, well after some more testing, I think my beocenter 2 cable is the faulty part. I doesnt seem to be making a good connection. Or it could be the socket units cable port. Does anyone out there have a beocenter 2 cable they want to sell?
Beolab 8000 x 2
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound Ouverture
Beolit 12
mbdj
Posts 74
mbdj replied on Tue, May 19 2020 3:10 PM
I had this problem with my beocentre 2 and it was a faulty power supply in the black box now fixed.
bigbruggsy
Posts 131
Silver Member
Hi mbdj thanks for the suggestion. What symptoms did your system show? How did you workout it was the powersupply? And was it something you fixed? Or did someone do it for you? The cost involved? I'm hoping Its either just the cable or a simple fix.  thanks again for your help.
Beolab 8000 x 2
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound Ouverture
Beolit 12
Page 1 of 1 (4 items) | RSS
