Beosound 5 Encore
Shearrow
Posts 2
Shearrow Posted: Fri, Apr 24 2020 10:20 PM
I have a Beosound 5 Encore, and when turned on, it displays "Checking Data, Please do not turn off". I am never able to proceed past this point. It will stay like this forever, Doesn't matter if I power off. I have tried everything.  Is there a way to re-load software or get to the menu?
Hungedu
United States
Posts 165
Hungedu replied on Sat, Apr 25 2020 5:52 AM
Maybe insert a new USB flash stick with some music on it and see if that gets the device to boot properly? Just an idea. Not sure if that will work, but it's worth a try.
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Apr 25 2020 5:58 AM
Shearrow:
Is it connected to the internet? If you use WLAN has something changed on the log-in credentials for the WiFi?
Try to use a LAN cable instead.
BeoMotion
Posts 384
BeoMotion replied on Sun, Apr 26 2020 5:38 PM
could be the same problem as described here.
https://archivedforum2.beoworld.org/forums/p/25632/207391.aspx
Shearrow
Posts 2
Shearrow replied on Sun, Apr 26 2020 8:22 PM
Thank you very much for this link:
I have torn the unit apart and found the SD card
Just waiting on a replacement
Thanks again
Page 1 of 1 (5 items) | RSS
