Hi Beoworlders,
is anyone else able to open service manuals they downloaded from beoworld? I tried several and they download properly, but if I try to open them it says the file is damaged. Thank you for your help.
I tried a few (on iPad) and they all worked. I suggest you try a different browser or/and PDF viewer. If it still doesn’t work, name a specific problem file and we will look into it.
--mika
I am sorry to hear that you have not been able to download the BeoVision 10-46.
I have done some tests from various machines and using different ISP's without problems using the BeoVision 10-46 Service Manual
I can only assume that the problem may be linked to download size limits of your ISP.
Are you able to download via a mobile network or different ISP?
Regards Keith....
You cannot send files of that size as an email attachment
I have split the PDF into five sections attached to this and the next four postings
Pages 30 to 44
Download the other pages on the links below
Pages 44 to 59 HERE
Pages 60 to 94 HERE
Thank you so much Keith! This level of commitment and help is what makes Beoworld truly special.
