Hi!
I got a set of Beovox speakers, which are missing the plastic-spacer for the bass-units:
It measures 2cm x 2,2 cm.Does anyone know where to buy this sparepart?
Thanks.
www.beoparts.com and use the contact form there or PM / email me.
PM sent. Do you know the correct name for describing this part?
Yes, in english it's called a clamp.
https://beoparts.com/2020/04/28/clamp-for-speaker-driver-bracket-2640038/
