BEO A9 Gen 2's Wifi connection issue
spawninc
Posts 5
spawninc Posted: Tue, Apr 28 2020 7:16 AM
I had a A9 gen 2 for years and recently its wifi connection stop working and the orange light indicator keep flashing. I did not change anything on the router setting. I tried to setup the wifi connection all over again andthis is what i have done:
1. Remove product from my B&O app
2. Factory reset
3. Connect to BEO A9 wifi, go to 192.168.1.1 and choose my home's wifi
After this setup, the B&O app is unable to detect the A9 at all.
However, when my phone connected to BEO A9's wifi, the B&O app is able to detect the A9. Something is wrong when add the BEO A9's wifi into the home's wifi network.
Any suggestion how to resolve the issue?
Jaffrey2230
Washington DC
Posts 520
If you have an iPhone, can you see the A9 as an AirPlay 2 device? May be you can try deleting and reinstalling the B&O App.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
spawninc
Posts 5
spawninc replied on Wed, Apr 29 2020 10:05 AM
I am using Android, basically i can't find it on Google Home, and Google Cast. It was OK last time, after I reinstall the app and reset the A9, all the apps are unable to detect A9.
Page 1 of 1 (3 items) | RSS
