Beovox M100-2 Recapp?
Andrew
Frinton, UK
Posts 917
Andrew Posted: Tue, Apr 28 2020 11:52 AM
Hi - I noticed recently that one of my M100-2s sounds a little quiter and less bass than the other - switched them over to eliminate the amp or the room and they still sound different. All the drivers work and I had a look inside the cabinets and they are immaculate but with the original capacitors/crossovers. Each speaker still sounds great, jusrt different so I am not sure what they should sound like now!
I tried to email Dillen but not sure if I did correctly, anyway, I wondered if recapping the crossovers would make a difference and if there is a kit I can get?
Rosewood
Posts 2
Hello, you did the correct thing. A couple of years ago I got a cap kit from Martin for these beasts! I don’t know to fastest way to get in contact. Regards, Matthijs
sonavor
Texas, United States
Posts 3,732
sonavor replied on Fri, May 1 2020 8:50 PM
Click on Dillen's (Martin) profile and use "Start a conversation" to send him a message via Beoworld. You may have to have messages enabled for your own profile.
-sonavor
Page 1 of 1 (3 items) | RSS
