beosystem 3 speaker modes
This post has 16 Replies | 2 Followers
cameron11
Posts 31
cameron11 Posted: Thu, Apr 30 2020 9:09 PM
Does anybody know if its possible to use two beolab 5s as front and centers an two beolab 3s as rears with a non b&o tv. At the minute my buluray player is decoding and sending 5.1 to the beosystem 3, but because there isn't a center channel i have no speech  thanks. The bluray has to be the processor.
cooldude
Posts 101
cooldude replied on Thu, Apr 30 2020 10:56 PM
Put it in speaker 4 mode.
cameron11
Posts 31
For some reason the beo4 remote seems to not be changing the speaker modes, I’ve even considered buying a beo5 just to see if that would work.
it sometimes changes between front speakers to all speakers, so I know it’s not the batteries or signal.
Any other ideas thanks?
DMacri
United States
Posts 881
DMacri replied on Fri, May 1 2020 9:29 PM
cooldude:
Isn’t Speaker 4 mode like “all channels in stereo” rather than a surround format?
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Esax
Posts 323
Esax replied on Fri, May 1 2020 9:53 PM
Speaker mode 4 is ”improved stereo mode”.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
OldJack
Split
Posts 371
OldJack replied on Fri, May 1 2020 10:41 PM
Get center speaker (7x)
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
cameron11
Posts 31
7 speakers are to bulky under flat tv and Beolab 5s would be a waste as just l and r
cameron11
Posts 31
You’re correct.
OldJack
Split
Posts 371
OldJack replied on Sat, May 2 2020 5:18 PM
I will go for BL 7.4
cameron11
Posts 31
I know I could add a speaker, yet what do people do when they’ve got a screen coming down from the ceiling. Not everybody would want a speaker left sitting on its own.
Dante
Sao Paulo - Brazil
Posts 163
Dante replied on Sun, May 3 2020 2:33 AM
I would get the speaker down from the ceiling too ;-)
kawo
Posts 148
kawo replied on Sun, May 3 2020 2:21 PM
I had a first a BL7-1 on the stand (there was a dedicated stand available in the past) and placed the speaker on a low board underneath the BV4.  Screen droped down to cover the screen for avoid reflections. Later I replaced the 7-1 with a 7-4, just put it on the low board. worked.
Esax
Posts 323
Esax replied on Sun, May 3 2020 8:55 PM
Why not beosound balance. Sounds wery god with speach.
crossbytje
Posts 224
The beocenter 3 should be able to port the center channel to both L+R speakers no?
Any AVR can do this (I'm using a Marantz one with Lab 9s as fronts without center speaker).
I must admit, having such omnidirectional beasts act as center is not optimal, voices don't really come from the screen area unless your speakers are placed right next to the screen (1.5 - 2m apart from each other..). Mine aren't, so I'm looking for a solution which doesn't ruin the clean look of the setup.
For now, I have placed an older Bose center speaker inside my floor convector, firing upwards. The result is rather ok.
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
Manbearpig
Posts 908
Hey there.
It should be possible to define what you want in the menu. But I guess you want several different speaker modes to choose from, of which the one you described is only one. In that case a Beosystem 3 with AST and a Beo 5 or 6 remote should do the trick. With AST you can flexibly assign speaker roles to different speakers and define speaker scenarios comparable to what you can do with several light controllers in a room. Unfortunately there is no way of switching between scenarios without a properly programmed Beo 5/6. Beo 4 can't do it and there is no command. Speaker 1-5 won't work. If you have an MK1 type 9600 Beosystem 3 you will probably run into trouble as well since those to the best of my knowledge do not have AST. But you will most likely need AST to do what you want if I recollect correctly. Therefore, you need at least an MK2 Beosystem 3. For remote controlling AST only Beo 5 and Beo 6 are suitable. All other remotes are unable to control AST. I have fiddled around with a similar issue quite some time ago and was surprised that nobody on here told me about the need of AST and Beo 5/6 to make proper use of it. I always thought this informaton was common knowledge, but apparently not. Maybe the same holds true in your situation now?
Greetings,
Kai
kallasr
Germany
Posts 2,562
kallasr replied on Tue, May 5 2020 7:11 PM
If you have not set up a center speaker you should get the center speech from left and right front speakers...
EDIT
Just saw this might not be possible with BS3 Sad
Google for Phantom center and Beolab 5, might find you something
EDIT
Ralf
Millemissen
Flensborg, Denmark
Posts 14,680
A ‘phantom center channel’ should not be a problem....if you sit in rhe right place.
However, this is only possible (with the BSys3) in stereo mode/with a stereo source.....and the op wanted to play 5.1 content!
As a workaround I’d play the 2.0 track from the bluray disc and set the BSys3 to Speaker 4.
Definitely not the best solution.
But the only way to have the dialog mixed into the main speakers.
Or rather - I’d seriously think about adding a center speaker......aesthetics aside.
It is the most important speaker in a 5.1 setup.
Page 1 of 1 (17 items) | RSS
