Beocenter 2 CTRL Socket
beoboehm
Berlin
Posts 48
beoboehm Posted: Sat, May 2 2020 2:35 PM
Hi everyone,
does someone know about the functionality of the Ctrl socket on the Beocenter 2?
Is it an input or an output?
Could it be used to trigger on/off an (off brand) active subwoofer for example or is it only for receiving IR signals?
The manual only says that it is neccesary to connect it when playing DVDs over Svideo, but not what it technically does.
As always: Thank you for your answers :)
Carlo
CB
> You are Here <
Posts 1,762
CB replied on Sat, May 2 2020 2:55 PM
Hi
Not an answer to your question, but this is what’s in the manual, page 7:
Audio/Video connection without a 21-pin AV cable ...
If your television is not equipped with an 21- pin AV socket, you can still connect it to the music system. This applies only if your BeoCenter 2 is equipped with DVD!
> Connect the CTRL socket on the Socket unit to the CTRL socket on your television.
> Connect the S-VIDEO socket on the Socket unit to the S-VIDEO socket on your television.
> Connect the VIDEO socket on the Socket unit to the VIDEO socket on your television.
> Connect the DIG.OUT socket on the socket unit to the digital input on your television.
> Connect the LINE OUT R and L socket for right and left channel audio output on the socket unit to the R and L sockets on your television.
beoboehm
Berlin
Posts 48
Hi CB,
That is why I suspect the BC2 sends a trigger to the TV. I was especially wondering if it only triggers out in DVD mode and if the trigger signal is usable for other equipment.
trackbeo
Posts 644
Service manual says it's a 3.5mm female jack where the inner conductor is "IR Out" and the outer conductor is "Not Connected".  The braid shield is labeled as just "Shield".  (I would think that one of the two *should* be GND for the electrical signal corresponding to the IR Out?)
beoboehm
Berlin
Posts 48
beoboehm replied on Mon, May 4 2020 12:35 PM
Thank you for checking!
I was hoping it could be a 12V trigger like on a "normal" system.
Gregg
Colorado USA
Posts 143
Gregg replied on Mon, May 4 2020 6:46 PM
I recently succeeded in getting a true DATALINK connection between my BC2 and MX5500 1988 vintage TV. The CTRL jack did not work as you suggested - I was unable to get any response between the BC2 and MX5500. I reason that is because the CTRL socket is only an output for an IR blaster, and does not receive B&O datalink.  The two are connected via S-Video as suggested by CB to the AV2 sockets on the MX5500.  I created a special cable by breaking open a SCART cable to access the DATA wire (Pin 8) on the BC2. I put a mini plug on that using the SCART cables shield for the ground on the plug. This breakout cable plugs into the SCART socket on the BC2. I now can start the DVD playing by pressing CDV on my Beolink 5000, which turns on both the TV and the BC2. I can also control menus on the DVD via the Beolink 5000 sending commands to the MX5500, which passes them on to the BC2. However, the reverse is not true; if I press DISC on the BC2, it does not turn on the MX5500.
Remarkable that these two products still integrate.
-Gregg
Page 1 of 1 (6 items) | RSS
