Beoremote 1 BT Amazon Netflix
thorne
Posts 315
thorne Posted: Tue, May 5 2020 7:31 AM
Hi
I am trying to attach Apple TV to the MyButton, of which I only have one.  I’ve looked up the manual on line but it’s all about the one with 4 MyButtons, and the instructions simply do not work with my remote
Any help would be very welcome
kuyttendaele
Posts 707
Just navigate to your AppleTV and press one of the 4 MyButtons for a couple of seconds. You'll get a message onscreen that the source has been added tot the button.
You can only add a source and speaker groups to the MyButtons; so just for example your Apple TV. You will still need to go to Netflix on your AppleTV.. The AppleTV Netflix app cannot be added
Karel.
Styrizo
Madrid
Posts 45
Styrizo replied on Tue, May 5 2020 9:14 AM
The BeoRemote One with Netflix and Amazon direct access buttons works just like the one with 4 MyButtons.
As kuyttendaele has said, just set your Beovision source to your Apple TV, adjust volume, the speakers group and stand position (in case you have a motorized stand) and press the MyButton for a two or three seconds until the onscreen message asking for confirmation pops up.
thorne
Posts 315
thorne replied on Tue, May 5 2020 12:06 PM
Thanks. Very simple to do. But the manual makes things sound a lot more complicated than that. Go onto lists, settings, advanced, buttons etc. Etc
thorne
Posts 315
thorne replied on Tue, May 5 2020 2:34 PM
Sorted. Thanks
Page 1 of 1 (5 items) | RSS
