Do the picture settings in Eclipse settings automatically apply to my attached Apple TV, or is there somewhere else where I can tweak the picture settings for Apple TV alone?
thorne:Do the picture settings in Eclipse settings automatically apply to my attached Apple TV, or is there somewhere else where I can tweak the picture settings for Apple TV alone?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Very helpful, thanks. So how do I choose which sources the settings should apply to? And if I want to apply them to all sources?
Hiort: You have to do the picture settings to you your likings in the picture settings of the screen. You can choose if the settings you do should apply to that input only or for all inputs.
If you - or someone else - are not aware of this, there are some B&O recommendations for the picture settings for the LG tv’s here (the second half of the video).
https://youtu.be/soABokgnIlE
All sorted. Thanks
thorne:Very helpful, thanks. So how do I choose which sources the settings should apply to? And if I want to apply them to all sources?
Millemissen:If you - or someone else - are not aware of this, there are some B&O recommendations for the picture settings for the LG tv’s here (the second half of the video). https://youtu.be/soABokgnIlE MM There is a tv - and there is a BV.
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
