Beo5 Recover
This post has 17 Replies | 3 Followers
apat
Greece
Posts 16
apat Posted: Sat, Jan 5 2013 4:48 PM
I after reviving and replacing the battery from my old Beo 5 I will embark in setting up movie room.
I have a PS3 on a IR/Bt adapter, SkyBox (amstrad drx890-z) and a Samsug 42ES6710
1) Any later firmware than 1.45b?
2) Any XML on SkyBox/Samsung TV
3) Anyone have something for Dreambox 500s?
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
A Very Warm Welcome to Beoworld...
  1. Your Firmware is fine.
  2. There is a recent posting with a Samsung XML which has been tested
  3. You will need to find on the web in Pronto HEX format the IR codes for Dreambox 500 which can then be converted.
Regards Keith....
apat
Greece
Posts 16
apat replied on Sun, Jan 6 2013 6:30 PM
I have obtained from the internet the following files
https://dl.dropbox.com/u/19565415/DM500s IR Codes.rtf
https://dl.dropbox.com/u/19565415/db7020.txt
does it help?
Keith Saunders
Posts 5,495
Using the Pronto HEX codes you have found I have produced an XML file with just a few commands for you to test to make sure they work before we go any further.
Attached is a ZIP file containing the test XML file. Please extract teh ZIP file to C:\ and it will automatically be added to the correct directory in teh B&O Configuration Tool.
Please provide feedback on how well these few commands work.
Regards Keith....
apat
Greece
Posts 16
apat replied on Mon, Jan 7 2013 8:39 PM
sorry for the delayed response but battery died. will get new one on friday.
Chris Harrison
Peak District
Posts 381
apat, Do you use the sky box connected to a B&O tv?
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
apat
Greece
Posts 16
apat replied on Sat, Jan 12 2013 9:40 AM
Nope. Standalone
Chris Harrison
Peak District
Posts 381
Ah I've been trying to get that working for years. Can you please email me the XML file for it? Thanks :- D
apat
Greece
Posts 16
Chris,,,,I have installed both of the attached XMLs and use part functions of one and part functions of the other to control my Amstrad SKY DRX890-Z.
It would be great if someone could merge them into one.
For reference we need to start from the Amstrad SKY XML file where Help, TV Guide, Options, BoxOffice, Mute and wheel/button functions all work.
From the Thomson XML file we would need to merge the POWER, SKY,  Interactive, Backup & UP/Down (inner wheel) to the Amstrad one...
Keith Saunders
Posts 5,495
apat,
You have not provided feedback with regards to the Dream 500 ?
Regards Keith....
apat
Greece
Posts 16
Apologies !
Results for the 6 Beo5 Screen options provided are as follows:
{BouQuet +} = does something like a page up or page back but could not correlate directly to DM500 Remote Function
{BouQuet -} = does something like a page up or page back but could not correlate directly to DM500 Remote Function
{POWER} = Red Power-On button on DM500 Remote [SUCCESS]
{Dream Menu} = Vol - / Left button on DM500 Remote [SUCCESS]
{UP} = OK button on DM500 Remote [SUCCESS]
{DOWN} = INFO button on DM500 Remote [SUCCESS]
Note that no other button on the Beo5 wheel produced any Remote function
I have attached a screenshot of the DM500 Remote for your reference.
apat
Greece
Posts 16
apat replied on Mon, Jan 21 2013 8:45 PM
bump
Chris Harrison
Peak District
Posts 381
apat:
Do you have a UK Sky Plus HD Box?
apat
Greece
Posts 16
apat replied on Tue, Jan 22 2013 7:44 PM
yes
apat
Greece
Posts 16
apat replied on Sat, Jan 26 2013 5:41 PM
Keith any way we can progress this ?
Keith Saunders
Posts 5,495
Yes, I will try and find time over the weekend to look at it.
The protocol used for this is XMP-1 which is a protocol that has two different formats. If you are doing a single command normally you do not have any problems, but if you have a repeat command, what it sends is a different command code. Unfortunately, the HEX codes you found had the single command but not the repeat.
So, basically I will need to actually decode the commands and create a repeat command list, hence that can take some time.
Regards Keith....
Chris Harrison
Peak District
Posts 381
Apat,
Did you get anywhere with merging the Sky box files?
apat
Greece
Posts 16
apat replied on Mon, Jan 28 2013 8:27 PM
started but got lost in the effort of the task....managed to fix two more buttons......investigating if there is a more efficient way to convert...
Page 1 of 1 (18 items) | RSS
