Using beomaster 7000 as pre amp for mono blocks
Golfjunkyrobert
Posts 2
Golfjunkyrobert Posted: Fri, May 8 2020 11:24 PM
Hi guys I own a beomaster 7000... I would like to know if it’s is possible to use the beomaster as pre amp if I use 2 monoblock s in my setup.... so cd 7000 beogram 8000 with Schiit phonopreamp to beomaster 7000 and than by line in/out (we’re is plastic plug) to monoblocks.....
systeem now Beosysteem 7000/cd beogram 8000 beovision 10-46 Beolab penta mark1 twice and Beolab penta Mark 2 also twice Schiit preamp for beogram and rega planar 2.....
thanks already guys
kind regards robert
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sat, May 9 2020 9:11 AM
Yes - assuming your monoblocks are pure poweramps with line level rca input sockets.
If they are balanced XLR you can use a converter or just solder them to unbalanced signal.
you can use Powerlink output sockets ( 8 pin DIN) for that - it, the preamp output of the BM7000. Volume control will work via BM7000 (Beoremote) too.
For the connection you will find 7pin DIN - 4x rca adapters. You will find wiring diagrams/pinouts On Beotech site .
the Powerlink output also has a trigger function on PIN 4 (5volt) for activating/deactivating your amps, but I’m assuming, they are always on...(?)
Welcome to Beoworld.
Stefan
Page 1 of 1 (2 items) | RSS
