1. Does anyone know how to source a white cover?
2. Or does anyone know how to change the cloth so as to replace the black with white? If it’s at all possible.
My local (SYDNEY Australia) B&O dealer has only been sent one (1) white replacement dome and of course I need two(2).
I'm open to any ideas, thank you.
I know of two here in Europe that can make them white for you if you're willing to entertain the idea?
can't your dealer order them anymore?
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Thanks, happy to entertain the idea. How would it work?
my dealer here in Sydney, ordered two and received one. They have told me that the factory does not make them anymore and I should try eBay?
3m3twinturbo:1. Does anyone know how to source a white cover? 2. Or does anyone know how to change the cloth so as to replace the black with white? If it’s at all possible. My local (SYDNEY Australia) B&O dealer has only been sent one (1) white replacement dome and of course I need two(2). I'm open to any ideas, thank you.
Thank you. I think you are correct in that I will need to look to Europe and a special order. B&O Denmark have confirmed that they no longer make these.
Overnight Beocovers reached out and we are discussing options. Too early to tell but it does look promising. I will let you know later.
Thank you for your response.
