Hello,
Setup:
Room1 BS9000 with LS connected by ML on BL3500 located in room2
Can we start BL3500 from room1 ?
The short answer is NO
Regards Keith....
And the long answer ? ;-)
Silou: And the long answer ? ;-)
The Masterlink protocol requires a device that wishes to provide an action (trigger from a button pressed etc) must be started by that device.
It uses what is called "Lock Management Protocol". Below is a typical communication sequence in the lock management protocol. Only one user is shown, User1 who operates Device1. Say that Device1 is a CD player, and that User1 wants to change track. The event key wanted is sent to Device1, which is not the lock manager. Therefore, Device1 requests the key on the network by broadcasting a REQUEST KEY telegram (telegram is B&O's preferred synonym for message). Device3 is the lock manager and is ready to give away the key. When Device3 sends the KEY TRANSFER telegram to Device1, the key gets reserved. Device1 is granted the key upon reception of the KEY TRANSFER telegram, and sends a NEW LOCK MANAGER to Device3 as an acknowledgement of a successful transfer. Finally, User1 gets the event key ready, and the change of track on the CD can take place.
You would be able to do this with a ML gateway and switch it on with your phone or tablet.
frog: You would be able to do this with a ML gateway and switch it on with your phone or tablet.
It's an idea, but I would to use only BEO4, thanks
Thanks for that explanation Keith.
I asked me if something was possible with Timer function... I thing it can do that but not by Beo4 reqest but it can start at certain time only.
