Beolab 8000 with SONY KDL-40EX500 TV - strange on/off behaviour
Dyssegaard
Copenhagen, Denmark
Posts 263
Dyssegaard Posted: Wed, May 13 2020 7:18 PM
My good old Beolab 8000s (MK1 from 1992 upgraded to MK2 in 2005) have started their 2nd life in my sons basement together with his SONY TV.
The volume controlled line output from the TV is connected to the line input on the 8000s with phono cables and the 8000s are switched to "line". The sound is perfect and controllable with the TV remote.
Here comes the problem:
When the TV is set to stand by, the 8000s goes to red after approx 2,5 minutes as expected. After another 2 minutes or so, the 8000s goes back to green, and a low humming noise is present from both 8000s. The 8000s stays in this state until the TV is turned on again. The humming disappears, and sound is good again.
Any ideas on how to fix this ?
Thanks in advance.
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Pat
Posts 152
Pat replied on Wed, May 13 2020 11:46 PM
Try another phono cables
Dyssegaard
Copenhagen, Denmark
Posts 263
Pat:
Thanks for the suggestion. I have now tried with a high quality well shielded cable, and the problem is still there.
My final solution will be to get an auto sensing power connector that will turn the speakers on/off together with the TV. Not elegant but effective Wink
Page 1 of 1 (3 items) | RSS
