New LG CX Oled has PUC control?
This post has 1 Reply | 0 Followers
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy Posted: Fri, May 15 2020 9:58 AM
I've looked through the specifications from the new LG Oled CX version on their site and saw that they mentioned explicitly the settopbox control through an ir-blaster. I can't find this feature in the C9 specifications.
Has LG adopted B&O's PUC control? So, does that mean that when you buy a new LG CX with B&O's Stage and Beoremote 1BT, you can control the setup with extra settopboxes with just only the BR1BT?
Millemissen
Flensborg, Denmark
Posts 14,680
That is not a new function on the LG tv’s
https://youtu.be/MKFgVJQwU5c
However, if that then makes it possible to use the BROne instead of the Magic Remote, is a .....very good question.
Perhaps someone could test it.
Page 1 of 1 (2 items) | RSS
