Why are N.Radio stations different on Beousound 5 and the Avant55?
Gregg
Colorado USA
Posts 143
Gregg Posted: Sat, May 16 2020 3:49 PM
I am getting a Beosound 5 up and running. Besides the obvious issue with a slow process for searching stations, one major station that is on my Avant 55 doesn't come up on the Beosound 5. I have the maximum buffer set, and cleared databases and reloaded on the BS5.
Is there any way to get a searchable list of all radio stations currently on N.Radio?
What URL does the Beosound 5 go out and touch to get the N.Radio list?
Thanks,
Gregg
beolion
Posts 485
beolion replied on Sat, May 16 2020 4:15 PM
Hi Gregg
I had earlier requested B&O to add missing radio stations to BS5 by sending them a request.
I suggest that you do the same a refer to specific radio channel on Avant so they can find the correct URL for radio streaming.
Leo
beolion
Posts 485
beolion replied on Sat, May 16 2020 4:17 PM
Oh. Remember to add the stations to your favourite list so you just have to enter Radio and a number from the favourite list Wink
Gregg
Colorado USA
Posts 143
Gregg replied on Sun, May 17 2020 12:50 AM
Thanks. Turns out I found the station under the name “classical kusc”. I found a trick for cutting searches shorter. Once you have favorites set, if you start playing a station then search it will start with that station’s name. By picking stations with starting letters around the alphabet you can save time.
Page 1 of 1 (4 items) | RSS
