Hi Guys,
I want to fit a IR transmitter cable into the back of my Beovision 7-40 mk 5, but it wont go all the way in ??
Its a standard 3.5 mm jack, I dont wont to break it, so is this normal ?
Ive also tried it wirh a Beovision 7-32 mk 5, same result, it goes about half way in.
Do I have to force it, or is there a special cable.?
Would like some help.
Ken
Nobody ? I dont want to break the TV.
Could you post a picture of that cable?
Where did you buy it - wasn’t it a ‘normal’ ir blaster cable from a B&O dealer, Soundsheavenly or alike?
Usually they fit well - push yes - but no need for forcing in in.
Is a standard aable van B&O and was with the TV, (would like to post a picture but its too many pixels so I dont know how to change the size.)
3.5 mm fits in every other stero ect that I have, but seems not to go all the way in with the Tv's.??
I could keep forcing it in, but wouldnt like to break the Tv
is the 3,5 mm jack stereo or mono?
Stefan
Should look like this
Same cable 3.5 x 14 mm
Is it surposed to go all the way in ?
Force it in, or just give up ?
Thanks for the help
Which cable do I need for the digital audio in A1 to A4 ?
JKW TAYLOR:Which cable do I need for the digital audio in A1 to A4 ? Ken
Thanks Lawrance,
Now I know what I got wrong, I mixed up the C1-C4 with the A1-A4
So I was trying to force a 3.5 IR blaster cable into the Digital Audio in.
Could not get to the back properly so trying to do it by feel.
Thank you all.
JKW TAYLOR:Thanks Lawrance, Now I know what I got wrong, I mixed up the C1-C4 with the A1-A4 So I was trying to force a 3.5 IR blaster cable into the Digital Audio in. Could not get to the back properly so trying to do it by feel. Thank you all. Ken
Good work takes time ;-)
Thats what is so good about Beoworld.
Tip & tricks that you dont find in the manual.
From members that really love Bang & Olufsen
Digital audio A1-A4, 1 connection is this mono ?
JKW TAYLOR:Digital audio A1-A4, 1 connection is this mono ? Ken
Thanks Lawrence,
Clear answer to my question,
