I have a new-to-me Beosound 5 and Beomaster 5. On the settings menu, between MAINTENANCE and MUSIC SERVICES (exactly midway on the arc) is supposed to be a PICTURE option. This allows you to set resolution output. This does not exist on mine. Anyone know why this may be? Is there a way to store. I've found nothing in all the various manuals, service manual, and service mode. Every other operation on this unit appears to be nominal.
Thanks,
Gregg
This is an option f you use the BM/BS5 in a Fully Integrated Master Setup - that is when you connect the BM5 to a (B&O-) tv.
You then have the choice between the different outputs on the Master5 depending on the inputs there.
MM -
Thank you. I have an Avant 32 with ML, and an Avant 55 with NL. So if I connect the BM5 via ML to the Avant 32, the BS5 will recognize the video master and PICTURE should appear?
-Gregg
Gregg: MM - Thank you. I have an Avant 32 with ML, and an Avant 55 with NL. So if I connect the BM5 via ML to the Avant 32, the BS5 will recognize the video master and PICTURE should appear? -Gregg
Hi Gregg,
maybe this can help you a bit......experimenting ;-)
http://www.iconic-av.co.uk/manuals/Beosound5_InstallationGuide-eng.pdf
Thank you, That will be a project for the weekend. I have to say, the BS5 is becoming one of my favorite B&O products. Other than the poor search facility for N. RADIO stations, it is a great product. I was surprised at how solid the old Windows XP-based software is.
I have a BV 7-40 coming next week so I will check that out!
