leosgonewild:Why are you using mk2 cables?
Because I have them.
Update:
I've replaced certain MK2 cables with MK3 going from the BeoSystem 4 to a Beolab 1 and a Beolab 6000 and found that it removed the data leak buzz.
-MK1 is indeed compatible with Beolab 1 speakers and they don't need MK3 cables.
-a daisy chain using MK2 from one speaker to another does not produce a hiss if the speaker connected to the BeoSsytem 4 uses either MK1 or MK3 but not MK2.
I make these clarifications because there are certain inaccuracies (or rather not the whole truth) with regard to the explanation given to powerlink cables. MK2 cables are NOT necessarily universal cables, and unless MK2 is actually needed, it's better to stick with either MK1 or MK3.
