I recently received a beocenter 8000 fom my parents, however the CD and Tape doors are not opening. I have opened the housing and both belts are broken. Does anyone know where I could by replacement sets for CD as well as Tape deck ?
I did find them for a tapedeck, but not for a CD player. The one I have found on ebay, is stating that it is for version 2 of the beocenter 8000, but how could i recognise if I have version 1 or 2 ?
Any help is appreciated !
Thanks in advence, Meindert Vos, The Netherlands
The door belts are identical for the CD and TAPE doors, if you require belt/belts for the tape player, Dillon ( Martin ) can supply the correct ones.
Keith.
Many thanks Keith, i have sent Dillen an email, based on your suggestion.
