Playmaker volume settings
This post has 2 Replies | 2 Followers
nico vercammen
Elversele, Belgium
Posts 174
nico vercammen Posted: Sun, Jan 6 2013 7:38 PM
Hi
I installed my new playmaker, but has some problems with volume settings
I connected it to the aux input of my BS9000
The PM is in option 0, so I hoped it has fixed volume ...
But i noticed the volume wheel is still active....
After poweron the volume is not at max level
Also after playing music via dlna, the volume setting can be changed by the dlna controller
So, next time i play a vynil disc, connected to the input on the PM, i have to change the volume on the wheel again...
I hope i'm doing something wrong ..
Can the volume be fixed on max level ?
Nico
Magnus
Norway
Posts 331
Magnus replied on Sun, Jan 6 2013 9:38 PM
I quote Vienna on this:
Vienna:
- To set PM to fixed voume use "A.SETUP" from "LIST", repeatedly "GO" till "S.STORE"
is shown in display , then "0", "GO"
Tried it myself, worked nice on Airplay – I didn't test it on DLNA or the line in, but I guess it will work!
Magnus
nico vercammen
Elversele, Belgium
Posts 174
It works now !
I tried this already but with no success ...
I didnt see you had to type the "0" before S.STORE ....
Also it should be in option 5 before you do this. Then back in option 0
Do not understand why this is not in the user guide ...
Thanks for helping :-)
Nico
Page 1 of 1 (3 items) | RSS
