IR eye - BLC NL/ML
This post has 5 Replies | 2 Followers
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic Posted: Thu, May 21 2020 11:14 AM
Hi all,
Quick question regarding IR eye, can a older version with PL cable be used on a BLC NL/ML converter (with RJ45 connection) using a normal speaker PL to RJ45 adapter? I can’t figure out how to get the IR eye work on de BLC and suspect the adapter trick is not working.
Thanks for sharing your thoughts
1990
Posts 521
1990 replied on Thu, May 21 2020 12:24 PM
I believe the wiring is different. You have to use the Join version instead of the Play version.
Millemissen
Flensborg, Denmark
Posts 14,680
This might help
Fansastic
Posts 768
Fansastic replied on Thu, May 21 2020 12:49 PM
Millemissen:
This might help
Great this helps! Thanks
Fansastic
Posts 768
Fansastic replied on Fri, May 22 2020 5:03 PM
1990:
You are correct, I got the join version from my dealer and it is for NL/ML - Essence mk2 - Core.
Fansastic
Posts 768
Fansastic replied on Fri, May 22 2020 5:05 PM
New question, anyone know if it is possible to change sound settings for the connected BL’s? If I select A-Setup on Beo4 I see bass-trebbe-loudness but cannot get it to react on anything.
Page 1 of 1 (6 items) | RSS
