Beocom 1400/1 IR module…
This post has 10 Replies | 0 Followers
matador43
Posts 1,373
matador43 Posted: Thu, May 21 2020 7:37 PM
Hi guys,
If anyone remembering, I do like to refurbish old Becoms for more modern use.
After bluetoothing a Beocom 6000, I'd like to wire the handset of an Beocom 1400 to my stupid-smart-phone.
All this to be able to lower the volume of the Beosound when a calls come-in. Anyway, containment…
My question is, how is the IR module powered? The base seems to be independent from the handset.
So is it battery powered or did I miss something? Pictures on the web are unclear about that and manual I've found don't seem to say much either.
I dont own the Beocom right now, just looking for one with IR module, but would use your advice before buying second hand.
Thanks to all.
madskp
Denmark
Posts 321
madskp replied on Thu, May 21 2020 8:09 PM
I had one quite a while back and it had a battery compartment with 2 or three AAA batteries
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, May 21 2020 8:41 PM
3 batteries, 4.5V dc.
I wired one from a Beocom 1600 like this once as a hidden volume control under my dining table:
matador43
Posts 1,373
matador43 replied on Thu, May 21 2020 8:53 PM
Hi Guy!
Big Smile Did you wire the Video button as to eject unwanted guests from their seat around the table?
Thanks you both for your answers!
Beozip
Posts 368
There is a secret "battery compartment" in the tablestand .....
Beozip
Posts 368
.... and in the wallholder .....
matador43
Posts 1,373
matador43 replied on Fri, May 22 2020 8:31 AM
Thank you Beozip, useful information indeed! I would certainly have not find that by myself!
As a side question, do anybody know how to open (dismantle) the handset? Thanks.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, May 22 2020 9:44 AM
matador43:
There's no easy way because it's glued together.  You basically need to 'break' it open carefully.
There's a picture here of an opened one: https://archivedforum2.beoworld.org/forums/p/3342/30285.aspx#30285
matador43
Posts 1,373
matador43 replied on Fri, May 22 2020 10:00 AM
Thanks.
Great help but bad news. Right now I have a lead on a said "brand new" one in box. Would be a shame to start by hurting it.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, May 22 2020 10:08 AM
Yes I couldn't do that to one in really good condition!
Have you considered a Beocom 1600, 2400 or 2500?  These have most of the electronics in the base hence would be easier to modify - plenty of space!
How/where were you planning to fit the BlueTooth battery/power for a Beocom 1400/1401 modificiation?
matador43
Posts 1,373
matador43 replied on Fri, May 22 2020 10:36 AM
As you may know I already have modified a Beocom 6000 as BT handset. The problem is the charge circuit is very fragile and it sometimes fail by itself preventing the battery to charge again. It happened twice already when i was trying to change bases.
My goal with that one is to do a wired handset and maybe some sort of stand for the actual smartphone where there is a little door for the notepad (if i could without damaging the unit). In fact it cames when I noticed the IR module and that the combo volume remote/handset/phone stand would certainly do a funny project.
It's built around a 1400/1401 just because there was one to sell cheap near me. But the guy do not answer and I find a second one (the brand new one) for a little bit more money but still not that much.
Right now I think I may suspend that project…
Page 1 of 1 (11 items) | RSS
DigiCert Secured Site Seal
