BC 9000 - Signs of Life?
BeoFrederic
Posts 276
BeoFrederic Posted: Fri, May 22 2020 3:56 PM
I’m a happy guy today.   I just purchased a long sought Attyca 2.  After looking for a few years for a unit anywhere in USA, the seller turned up not 20 miles from my house.  Oh-and-by-the-way, the seller included a BC 9000 and two RL 140s.  (!)
The BC 9000 that isn’t functioning…yet.  Perhaps someone can point out a simple user-interaction fix.
Status: the unit is in very good + cosmetic shape, so I infer it wasn’t abused.  The bottom glass panel is loose, of course, but I’m able to seat it in the tray.  When I power it up, there’s a tiny red light in the top right of the top glass.  Simultaneously, ‘Clock’ is illuminated on the bottom glass.  The glass doesn’t respond to my touch and there is no standby light.
I have both a Beolink 1000 and a Beo4; selecting ‘Menu’ brings up ‘Play’ ‘Record’ ‘Call’ sub-menu on the glass for a few seconds.  Selecting anything else, e.g. ‘Radio,’ causes the bottom panel to flash illuminate for a sub-second.   It’s as though the unit was somehow locked.
Does the clock need to be reset before the unit will release/respond?  And if so, how?  The manual say to select ‘Programming’ but there is no ‘Programming’ illuminated/selectable.
Or does this unit end in the closet for spare parts?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, May 22 2020 4:24 PM
Check the power supply module for cracked solder joints.
Particularly at the large filter capacitors.
The glass panel will not work until correctly fastened.
BeoFrederic
Posts 276
Thanks for the rapid reply, Martin.
Page 1 of 1 (3 items) | RSS
