Use BL 5's and other equipment with HDMI
This post has 4 Replies | 2 Followers
primmdaddy
Posts 3
primmdaddy Posted: Sat, May 23 2020 6:14 AM
B&O enthusiasts,
I have recently had to move a significant amount of AV equipment that a friend of the family had to give up due to housing changes. There is a large amount of B&O equipment. I will paste the list below. I have tried to sell some of it (with no luck in rural Alabama), but can keep the BL 5's - if I can find a way to adjust the volume. In the move, all remotes have been lost. Not shown in the equipment list are several IR receiver/volume control modules and various cables.
I would like to have several HDMI sources (Cable, FireTV, BD, Game) and output HDMI to the TV and volume control the BL5's. Can I do this with any of the existing equipment on the list or should I bite the bullet and buy a Beo4 on eBay? I would like to use digital coax but may need to resort to analog RCA. I don't want to start up an old Windows XP computer (Beosound 5) to watch a couple of TV shows before bed. Any suggestions for how to use this equipment would be welcome. High end AV equipment is such a double edged sword as I have not had any luck selling this equipment for the previous owner at respectable prices and do not want to let it go to waste. I have been reviewing this forum and others but do not see a clear path forward for my situation.
BTW, I have e-mailed Steve at Sounds Heavenly, twice, with no response. I have used links or his store e-mail. I am hoping some of you have great suggestions!
Thanks to all!
Component Manufacturer Model QTY Condition
Speakers Bowers and Wilkins Matrix 800 Series 1 #360 2 Good
Bang & Olefsun Beolab 2 1 Good
Bang & Olefsun Beolab 3 4 Good
Bang & Olefsun Beolab 5 2 Very Good
Bang & Olefsun Beolab 3500 1 Fair
Bang & Olefsun Beolab 4000 mk1 2 Fair
Bang & Olefsun Beolab 8000 mk2 2 Very Good
Triad Platinum LCR Front L+R, C + Sub 1 each Fair
Polk CSi6 (center) 1 Good
Definitive Tech Powerfield DT-0033 12” Sub 1 Good
Amps Aragon 8008x3 1 Good
Krell FPB-200 1 Good
Halcro MC-70 1 Good
Cambridge P500 1 Fair
Receivers Harmon Kardon HK880VXi 1 Fair
Denon AVR-1912 1 Good
Power Supply Monster Power HTS-5100 1 Good
Monster Power AVS-2000 1 Fair
Richard Gray Pole Pig 6 outlet 1 Good
Richard Gray RGPC400 Pro 2 Fair
Richard Gray Extender 1 Good
Pre-amp Krell Home Theater Standard 5.1 1 Fair
Krell Audio + Video Standard 1 Fair
Denon AVP-A1HDC1 1 Good
Sony EP9ES 1 Fair
Media Sources Pioneer CLD 1090 Laser Disc 1 Fair
Pioneer PDR W839 3+1 CD 1 Fair
Sony CDP CE235 1 Fair
Sony DVP-S7700 1 Fair
Toshiba SD9200 1 Fair
Nakamichi CR-1A 1 Fair
Revox B790 1 Poor
Other Bang & Olefsun BeoVision 5 1 each Good
Bang & Olefsun Beosound 8 1 Good
Bang & Olefsun Beosound 5 1 each Very Good
Bang & Olefsun Beomaster 5 1 Good
Bang & Olefsun Beolink Passive 1 Good
Bang & Olefsun Beolink Active 1 Good
Bang & Olefsun Beolink Wireless 1 NIB
TWG
Posts 1,672
TWG replied on Sat, May 23 2020 9:40 AM
you can use RCA or digital connection from any source of your choice but the Beolab 5 have to be set up accordingly. For that you'll need a Beo 4 remote.
When using them with non Bang & Olufsen sources a synchronisation cable is required between both speakers to ensure that they both play the same volume level.
Userguide: https://bangolufsenassistentgohe.blob.core.windows.net/manuals/SPEAKERS/BEOLAB%205/EN-BeoLab5.pdf
primmdaddy
Posts 3
primmdaddy replied on Sat, May 23 2020 10:28 PM
TWG,
Thank you for the reply. I had downloaded the manual and saw the requirement as well. I had hoped in the intervening years, a new method was available. The more remotes we have, the more resistant my wife will be to allowing me to use the equipment! Listening to the BL 5's through the Beosound 5 was great, but the Beosound is entirely too finicky, with limited inputs, to be a long term solution.
If anyone has other suggestions or has code to make a Logitech Harmony compatible, please advise.
Thanks again!
primmdaddy
Posts 3
I think I have a more elegant solution to my problem. I have ordered a used Beo4 on e-bay. The elegant part here is how to get a source signal and not fool with a receiver/pre-amp. Not shown on the equipment list above (but now seemingly very important) is a Monarchy Audio Digital Interface Processor (DIP). If it works, I believe I can output the the digital optical output from the TV to the DIP. The DIP should then output a digital coax to the BL5's. Add a sync cable and I think I've got it covered. Then my wife can watch her shows with or without the BL5's and I can watch my shows while she's at work (night time ICU nurse) with some incredible sound. I believe I'll need to use the Beo4 for on/off and volume, correct? I think this will be the simplest solution I can find. Any opinions?
Barry Santini
New York
Posts 543
primmdaddy:
Yes. Buy a Beovision
Page 1 of 1 (5 items) | RSS
