Refoaming S45 speakers - supplier suggestions?
This post has 3 Replies | 0 Followers
synth
Off piste
Posts 105
synth Posted: Sun, May 24 2020 8:31 AM
Hi
My Fathers S45 speakers need new foam suspenson as the foam has perished over time and use. I temember listening to my fathers classical music on this system ( 7007 ) and being amazed at the quality.
I have a set of Redlines and BL3s as well as a 7-32 tv.Listening to the 7007 started me down my B&O addiction....Smile
Can anyone suggest a high quality foam kit supplier so i can bring th e speakers back close to original spec please?
Thank you/Danke/Merci
Sehrbug
Posts 15
Sehrbug replied on Sun, May 24 2020 11:37 AM
Hi Synth,
Here is the link for the Audiofriends
https://www.repairyourspeakers.com/en/foam-surrounds/bang-olufsen/bang-olufsen-s45-1x-foam-surround-for-repair-woofer/a-158-10000016
Audiofriends are very good for it.
synth
Off piste
Posts 105
synth replied on Sun, May 24 2020 10:06 PM
Thank you very much
Smile
synth
Off piste
Posts 105
Thank you very much
Smile
Page 1 of 1 (4 items) | RSS
