V8000 sudden loss of picture
This post has 4 Replies | 0 Followers
david707
Posts 146
david707 Posted: Sun, May 24 2020 10:10 AM
All scarts are properly connected and fully working then total loss of picture. Sound is working as normal. Tapes play fine on a V6000 so no issues with them. Any suggestions?
Pat
Posts 152
Pat replied on Sun, May 24 2020 3:30 PM
Try scart lead, then another scart socket in the tv.
Tayne
Posts 38
Tayne replied on Sun, May 24 2020 5:25 PM
If you narrow it down to a mechanical fault, it will most likely be a pinch roller. They wear our fairly quick compared to the rest of the unit. Given its age, it isn’t worth repairing!
david707
Posts 146
david707 replied on Mon, May 25 2020 9:25 AM
Tested with different scart leads and sockets. It was in full working order and used for many hours without fault immediately prior to this.
david707
Posts 146
david707 replied on Mon, May 25 2020 9:27 AM
Thanks. Would the pinch roller wear out suddenly? The unit has been in use for many hours without fault in recent days.
Page 1 of 1 (5 items) | RSS
