Hello :)
I think I've reached the end of my road with trying to fix this Beomaster 6000, but while I am waiting for a shop to take it in, I was hoping there is something I could do to figure it out.
I am not getting any audio from all inputs except from the "external" input, but PH, TP1, TP2 (DIN or RCA) are all inoperative. I am thinking it may have to do with a channel source selector switch or relay somewhere on the amplifier board? Can anyone help me locate what component could have failed and is not changing sources properly? The display shows the proper channel that I select but no audio from those sources.
Thanks so much for your ongoing help!
If you are not using the EXT output/input loop socket, you should fit a blinding plug.Else everything else will be silent.
https://beoparts.com/2017/05/30/beocenter-5000-7000-7002-7007-7700-blinding-plug-7220265/
Can't believe it was that simple....
Just built a blinding plug, and wahlah! thank you Martin, its nearly working perfectly now haha!
Boy what a newb i am...
