beo5 configuration tool doesn't work with windows 7 64 bit
This post has 13 Replies | 4 Followers
lucabart
Posts 1
lucabart Posted: Tue, Mar 13 2012 5:21 PM
do is possible that beo5 configuration tool won't work with windows 7 64 bit? is there an updated version?
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
You are correct that the Beo5 Configuration Tool will ONLY work on 32 bit Windows operating systems.
There is currently no update..
Regards Keith....
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Is your Beo5 recognized by the device manager?
If so, and still the Beo5 service tool doesn't recognize the Beo5, it is because of the driver certificate.
I did this.
Press F8 to start windows 7 with the option "use drivers without cerificate". Then the Beo5 config tool works.
Beobuddy
Posts 3,972
Here's my device manager.
hackel
Posts 30
hackel replied on Mon, Apr 9 2012 4:03 PM
You'll have to use Windows XP mode and then install the configuration Tools.
It's work with this mode, the only thing you'll have to do is to connect the USB during the transfer.
vimavi
Posts 1
vimavi replied on Mon, Apr 9 2012 6:10 PM
Thanks. Bedankt.
It works fine, update firmware and configuration done.
Smile
Niederrheiner
Posts 28
hi,
just wait a few days....
B&O announced a new Config Tool for week 18/19....
there should be a new FW (v3) for beo 5/6 an dthe SW should
work on windows7 64bit....
The only thing to be done is, to upgrade the FW V3 on a 32bit system,
after that it will be recognized on a 64bit system....
OlliNeu
Posts 21
OlliNeu replied on Thu, May 17 2012 12:20 PM
are there any news to the new version? Is it already available?
Is there any link to download?
BR
Michael
Sweden
Posts 2,578
Michael replied on Thu, May 17 2012 12:45 PM
im a bit impressed that you run Windows 7 on just 1Gb ram (!) and with that small amount of memory there is no need for windows 64-bit. If you have less than 4GB ram, then 32-bit OS is absolutely enough.
Perhaps a bit off topic but thats how it is anyway :)
But, of course, Mac is better anyways ;)
Niederrheiner
Posts 28
Hello,
the new ConfTool V6 is launched with the new FW V3.
It works with the Beo6 together on 64 bit Systems.
Cheers,
Niederrheiner
Keith Saunders
Posts 5,495
Niederrheiner:
Whilst B&O have released the new version 6 of the configuration Tool which supports 64 bit machines, BUT only for the Beo6, NOT the Beo5
Also, the Beo6 MUST have its firmware upgraded on a 32 bit machine BEFORE using on a 64 bit machine. The reason is that the current firmware in your Beo6 is still looking to receive data in 32 bit format.
Once your Beo6 has had its firmware upgraded for use on 64 bit machines, theres no going back, well not unless you are very technically knowledgeable.
Regards Keith....
Michael
Sweden
Posts 2,578
Michael replied on Sat, May 26 2012 9:19 AM
Keith Saunders:
How strange is that if it really is true? It should work good both on 32 and 64 bit computers. You dont need to buy a 64-bit printer to work with 64bit operating systems for example. Or anything else. If it is like that I really dont understand what the developer has done.
hfat
Vienna, Austria
Posts 663
hfat replied on Sat, May 26 2012 9:23 AM
Keith Saunders:
Is there an option to keep the FW in 32 bit mode?
Are there any new functions in the FW and/or the config tool?
hfat
Griebel
Posts 416
Griebel replied on Sat, May 26 2012 9:40 AM
Didn't see anything for FW, but the tool now includes the BeoPlay.
Page 1 of 1 (14 items) | RSS
DigiCert Secured Site Seal
