Beovision7 mk 3 set up Apple TV help
Zchael6
Posts 2
Zchael6 Posted: Sat, Jun 6 2020 2:16 PM
Hi there!!
I have recently aquired a beovision7 type 9334 and I’m trying to set up my mk3 Apple TV on it.
I plugged in the Apple TV through a video converter which has hdmi from the Apple TV going in and then dvi coming out. Also coming out was a headphone to rca audio cable.
 Initially when on the DTV mode as selected on my beo4 remote, I got the image from the Apple TV but no sound. I tried setting up the sound and now I don’t have vision or sound.
Im struggling to set it all up via my beo4 remote in the menu- options- connections panel while on TV mode
im not sure whether I’ve connect the audio rca into the right sockets on the back of the beovision7.
 This is a link to the converter I have
https://www.amazon.co.uk/eSynic-Converter-Extractor-Adapter-Optical/dp/B07PG1B4NX/ref=sxts_sxwds-bia-wc-p13n1_0?cv_ct_cx=hdmi+to+dvi+converter&dchild=1&keywords=hdmi+to+dvi+converter&pd_rd_i=B07PG1B4NX&pd_rd_r=7bd4889f-7eed-4bdd-955a-48f3c2290e68&pd_rd_w=9dV71&pd_rd_wg=alSjh&pf_rd_p=3706c3bd-3266-4c7b-88b8-55890dca63c0&pf_rd_r=ZSJYAFDCG2XJQTEFWX2K&psc=1&qid=1591449342&sprefix=hdmi+to+dvi+&sr=1-1-e4abe256-0722-424e-a8a3-6caa9bba7df8
any info or advice would be greatly appreciated! Thank you!
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sun, Jun 7 2020 1:23 PM
If it`s a BV7-32 mk3 and if connections are similiar to BC6-26 and if I remember correctly, then try AV3 with stereo rca inputs and assign the DVI socket to AV3
Welcome to Beoworld.
Stefan
Zchael6
Posts 2
Zchael6 replied on Sun, Jun 7 2020 3:25 PM
Hi there Thanks very much for the reply. I still have no luck getting picture or sound from the Apple TV. Initially I did get a picture but I must have messed with the settings. When in connections, what exactly should each of the AVs 1-4 have as their 1 source 2 audio socket 3 Ir socket 4 hdtv I’m quite confused sorry
Page 1 of 1 (3 items) | RSS
