trouble shooting advice CX75
Der_Rudi
Posts 2
Der_Rudi Posted: Sun, Jun 7 2020 11:16 AM
HI All,
I just refoamed a pair of CX75 (only the top drivers) and this was not a bad job at all. But now I tested them and they really sound as a beverage can. I didn't test them beforehand.
Now my question where to start with troubleshooting?
As I'm quite new to this.
Already measured the disconnected drivers with my ohm-meter and all are around 5,5 ohms which sounds about right?
did some more testing and i gt sound from the refoamed driver when connected directly to my pi-zero mini amp. but still weak. when connected to the rest there is absolutly no movement.
also tried to center them again but there is no rub no notice
Thanks!
Der_Rudi
Posts 2
gentle bump
any help would be highly appreciated
Premiumverum
Netherlands
Posts 115
A couple of suggestions:
Did you reconnect the driver correctly? If you mix up + and - it will be out of phase, this will affect the sound.
Are both CX-es connected to the amp correctly?
What amplifier are you using?
Did you use a correct surround for the repair?
Page 1 of 1 (3 items) | RSS
