Hello,
I need your help to get information regarding Beolab5s MK version/ year of production :
Here what I have from this post * :
- From serial number 17659943 New Software 1.6 : MK 1
- From serial number 17772145 you can sinconize 2 BL5 whit extra cable and PIN CODE intro : MK ?
- From serial number 17910097 New Software 2.6 : MK ?
- From serial number 18512908 B&O have change the fix system of freats : MK ?
- From serial number 19375256 some change (???)
- From serial number 19900141 B&O has change POWER CORD.: MK ?
- From serial number 21221146 New Software 3.00a: MK ?
- From serial number 21770424 New Software 3.10a: MK ?
- From serial number 21981978 NO Brush in the box: MK ? (2011)
- Serial number 229xxxxx New Software 3.2 (2012)
- Serial number 240xxxxx New Software 3.2 (2014)
Infos Beocentral :
(2003-2017) 4-way loudspeaker, Powerlink, 2500W total output
Type numbers: 6881, 6882, 6883, 6884, 6885, 6886, 6887, 6888
Thanks for your help,
Cheers,
* (https://archivedarchivedforum2.beoworld.org/forums/t/39408.aspx)
* (https://www.beoworld.org/beotech/beolab5service.htm)
BV10 46" - BL5 to come... BS Ouverture, BC6000, BT1100
Old sold : BV Avant 28", BL8000 - BL4000 - BL2
I'm very curious as well, good question
