Beomaster 5000 Capacitor kit and restoration
Reynold1
Posts 2
Reynold1 Posted: Thu, Jun 18 2020 5:53 PM
Hello everyone! I’m new here and have a Beomaster 5000 that I am looking to restore. I hooked the unit up as a preliminary test and it does function, but I am all too well aware of the need to replace capacitors and components in older tech. I am looking for a capacitor/DIY restoration kit and didn’t find much info from a google search. Can anyone here point in the right direction? Thanks!
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Craig replied on Sat, Jun 20 2020 7:50 AM
Hi
You can download a copy of the service manual here on Beoworld if you upgrade your membership to silver, you will need this. As for replacement capacitors Dillen (our resident oracle of all knowledge B&O) may provide a kit containing all the required parts, not sure if he covers this unit but it is worth asking him first. There are not a lot of caps to replace, however you should look to replace the trimmers as they do oxidize and fall over, check my post below for an idea of whats required.....and post some pictures so we can help out if needed.
Regards Craig
https://archivedforum2.beoworld.org/forums/t/38080.aspx
Reynold1
Posts 2
Reynold1 replied on Tue, Jun 23 2020 6:03 PM
I have the later Beomaster 5000, I didn't realize there were two versions! I clicked your link and was pretty confused at first! But I opened mine up and have started making capacitor lists and everything to see what I need.
sonavor
Texas, United States
Posts 3,732
sonavor replied on Tue, Jun 23 2020 10:42 PM
I got my Beosystem 5000 working back in 2015. Here is the post of that project. It included recapping the Beomaster 5000. Later I restored a Beosystem 5500 which I have ended up using more. Both are nice systems.
-sonavor
gridrunner
Posts 1
I'm about to restore a whole Beomaster 5000 stack. I'm in the position - I'm looking for parts.
I ordered a cap kit from here : https://www.audio-high-store.com/product/bang-and-olufsen-beomaster-5000-upgrade-kit-audio-capacitors/
A month later though, it still hasn't arrived and their customer support isn't telling me where it went. It is not like I can't afford to lose 50 euros - but I am time poor and I'm worrying I might die of old age before this gets sorted out.
Can anyone else direct me to where I can get a cap kit. I'm also after belts etc........
I would really apprecite some help here.......
Best,
-Daz.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Jul 22 2021 6:26 PM
Belts etc. can be found at Beoparts-shop.
Capacitor kits are in the making.
Don't buy kits where low-ESR capacitors are put to work in the output stage. It's asking for self-oscillation.
Moruller
Posts 1
Moruller replied on Sun, Jul 25 2021 7:27 AM
This is probably the place. I have used it several times and they are serious.
https://www.beoparts-shop.com/
matador43
Posts 1,373
matador43 replied on Sun, Jul 25 2021 1:30 PM
sonavor:
Hi Sonavor,
May I ask why you ended up using the 5500 more over the 5000? I've read somewhere that the 5000 sound better than the 5500 which is kind of Japanese average hifi, unless you chop-chop parts from him.
I'm asking because I have a 5000 system running with a beomaster 5500 and alongside two faulty BM5000, I dont know where to start with.
And even if the difference in display hurts my sight, I wouldn't want to invest too much time into something that would not "sounds astonishingly better".
sonavor
Posts 3,732
sonavor replied on Sun, Jul 25 2021 3:03 PM
Between the two 5000/5500 systems I restored for myself I haven't noticed one being distinctively better that the other. Both Beomaster amplifier sections do fine and sound good. I read on Beocentral that the radio section of the Beomaster 5500 wasn't as complex as the Beomaster 5000. Beocentral felt it was a cost saving move by Bang & Olufsen. I don't listen to the radio enough with either of them to know if that is true.
I do use both Beomaster units here at home. I use the Beomaster 5500 with its companion components in a nice Attyca cabinet.  I use the Beomaster 5000 as a test unit in a listening room as another stereo amplifier to test listening to various B&O components.
I still prefer listening to a Beomaster 8000, a Beomaster 4400 or a Beomaster 6000 (type 225x) over any of the later Beomaster/Beocenter products though. So my use of either Beosystem 5500 or 5000 is significantly less that with the earlier Beomaster receivers.  Hopefully this year I will finally add a couple of Beolab 5000 amplifiers into my listening rotation.
In answer to your question I don't feel that you would hear much (if any) difference between the 5500 and 5000 systems providing you used the same speakers with both.
-sonavor
Page 1 of 1 (9 items) | RSS
DigiCert Secured Site Seal
