Hi, everyone.
I recently got my families old B&O sound system and it all work well apart from the record player in which the arm doesn't track when playing records. I checked inside after reading up on multiple forums on this site and it has been a real help.
I have come to the conclusion that it is the LDR or Photo resistor that is at fault as the bulb works fine when the stylus is in contact with a record.
My main question is if anyone can give me a suitable replacement for it that is the same or close to the original. I cannot find stats on the LDR very easily so would appreciate any help with this problem. I am happy to get another but need requirements like resistance and voltage.
Thanks, Adam
hi adam,
if still current, Beoparts-shop has these parts available.
regards
ALF
