Anybody with a Beosound 5 / Beomaster 5 setup able to make a Wifi connection as a opposed to a Wired connection. If so would they be kind enough to share their solution
Thanks Nigel
I have mine wired to an airport express. Works great.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Just use any wireless access point / repeater with an Ethernet / LAN port. set it up for your wireless network and connect it with a LAN cable to your Beomaster 5 and you're ready to go and you avoid messing around with the Beomaster 5 software. An Example is the Airport Express or other small access points.
Agree - that would be a better and easier solution.
Orherweise consult this guide - page 32....
http://www.iconic-av.co.uk/manuals/Beosound5_InstallationGuide-eng.pdf
