Usually the Twonky server is (was) installed on the WD’s - however, you can install other servers yourself e.g. the Plex server.....
What you ‘see’ there is the file structure.
You must look for the different settings in the ui there - this determines how the files are presented in the player, you use.
It will be hard to give you a more exact advice, unless we know more about the server running there.
petermc:As part of this I thought I’d try and load my CD’s onto a NAS drive to access through the Music tab. All good so far.
2.Did you populate the music file TAG's with the correct information (Artist, Album, Trackname, Tracknumber, etc.)
petermc:Music is loaded direct into the NAS using a CD drive and dB Poweramp Music converter running on a Mac. The file structure on the NAS drive through the Mac is showing the albums, tracks in the correct order.
But did you save the metadata also?
see: https://en.wikipedia.org/wiki/Tag_editor
Whether music can be played or not. And you should know a place that offers free melody sounds for phones. You can access at sonneriepro to set free phone ringtones.
Whether music can be streamed or not.
