My BeoMaster5 has been downloading new software for the last 14 hours... now 59%
Have anyone managed to try the new version? Is Spotify finally included?
Hmm, just checked mine, no new software here in Denmark, where are you from ?
Peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Good to hear B&O are still tweeking the BM5, but 14 hours its either massive or your broadband is very slow.
Please keep us posted !!!
The new update will add support for favorite recipes and a 24 hour clock when unit is in standby.
BeoSound 5 - In option 1 the volume will be raised to default when re-activated from linkroom"We have solved this in software 6.06 released January 9th 2013.
nico vercammen:Very curiuous what the update will do. ..
I've been told it solves mainly N.RADIO issues (caused by the currently used version of the media player) by replacing the media player, cover art for FLAC and some other issues.It took approx 20 hours to reach 90% ... not finished yet.
Mine is saying 6.06.00.4176
Hi Peter,
I'm in Denmark and on a 100Mb fiber.
Now 66%... :-)
Mine is right now 47% (Denmark)
Cheers
45% (Holland)
I updated mine yesterday, took 10 Minutes, I must have been one of the first.
Hmm, I dont notice any difference, the good thing is, everything still works :-)
Update finished.
Manual setting for "netradio buffer time" disappeared - new automatic function for buffering NETRADIO seems to work well.
no spotify?
@koning
Definitely not!
http://archivedforum2.beoworld.org/forums/t/4114.aspx?PageIndex=2
Post from 01-09-2013 1:40 PM
Millemissen: @koning Definitely not! http://archivedforum2.beoworld.org/forums/t/4114.aspx?PageIndex=2 Post from 01-09-2013 1:40 PM Greetings Millemissen
Thx
"New features
·The driver for Linksys AE2500 wireless USB network interface card is included
·A new player component is introduced to improve net radio playback Please note: The N.RADIO BUFFER setting is removed from the menu as a consequence of the new playback design."
Don't even think of Spotify.
What is the new software version ?
Some of my classical radio stations have disappeared on BS5/BM5 (Abacus**, 1fm**) but they play nicely on the "TuneIn Radio" app.
Anyone who knows whether this is a software issue and will be corrected in the new update?
Cheers.
That should be an issue for Beocare - must be asked!
The update is now finished and a quick look at the display reveals no changes. As for the missing stations they have not returned.
I have just sent a request to BeoCare.
Thank you and
Hi, I have tried to download the new software with my Beosound 5. But it just says 0% and nothing happens. I tried yesterday evening at 10 pm and let the download progress thru the morning. But still 0%. Is the server with the new software down or does it work fast now? Does anybody know?
Regards Martin
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Maybe the update has been downloaded automatically? Check the version#
martin01:Hi, I have tried to download the new software with my Beosound 5. But it just says 0% and nothing happens. I tried yesterday evening at 10 pm and let the download progress thru the morning. But still 0%. Is the server with the new software down or does it work fast now? Does anybody know? Regards Martin Beovision 7-55 3D with Bluray, Beolab 5 (sw 3.0), Beolab 3, Beolab 3500, Beo4, Beosound 5, Beomaster 5, Beosound 9000 Mark III (sw 2.4)
I have tried to download the new software over the weekend. But it does not work. The Beosound 5 finds the software but it will not start the downloading. The display just says "Downloading 0%". The percentage does not change from zero.
The software in my Beosound 5 is 6.05. What could be wrong with my BS5, or is it maybe B&O:s server that does not work.
/Martin
Problems addressed
Net radio stations cannot be played or buffer for several minutesSeveral drop-outs while playing certain net radio stationsCover art not shown with FLAC filesNot possible to reduce volume to '0'BeoLab 3500 - Display always shows CD-128 In option 1 the volume will be raised to default when re-activated from link roomEnters standby without warning during normal use Inactivity timer turns off other main room products as well
Problems addressed - before 6.0.6!!!
We could use this thread to sum up the problems after 6.0.6 - for posting to the BeoCare.
Cover art not more shown in FLAC files. Was available in earlier software.
Beovision 10-46, Beo6, Beosound 5+ Beomaster 5, Beolab 12.2, Beolab 12.3, Beocom 6000
That was a problem that the new sw should solve!
How do you "save" the covers? As folder.jpg or embedded in the file?
BL 3500 shows as before: A.Tape.
Flac covers are shown as before (embedded in flac file)
I still can play Apple Lossless files since some previous update. Double checked it and rechecked it (Note the BS5e does NOT play these same files. So Twonky is NOT transforming them! ) Files converted with EZ CD Audio Converter to Apple Lossless and are situated on an extern NAS with Twonky 7.1.2
Twonky after update in BM5 is still version 6.x.x
Embedded in the file by mp3tag.
Also the jpeg file is in the folder. Behoren the update I had coverflow of flac music.
Solex: Cover art not more shown in FLAC files. Was available in earlier software.
No problem with coverart i FLAC files here. Not before the update and not after.
Having the BM5/BS5 combo play Apple Lossless after the update is too much to ask. Isn't it?
@Solex I would try to rebuild the library/reindex the files.
I would also try Media Monkey's edit function for the album. Choose the cover art tag. If you have several covers associated with that file, Media Monkey will show them all, and let you delete the ones you don't want. Then have you BS/BM rescan and the art you left should show up.
B
