Hello all,
The recent talk around here about multi-channel audio got me thinking over the weekend (uh-oh). I have a pair of BL8000s and BL4000s that I'm not really using and was considering adding them to my Eclipse for multi-channel. Given the layout of my room and location of the BV, wiring some of these speakers is not really an option. The layout of the room (walls, open walls, seating arrangement) will also be a problem for speaker placement in general, but maybe B&O surround processing magic can help with this, but this is a discussion for another day.
Are people now mostly happy with WISA performance?
I saw some threads from a few years ago with people complaining about interference between their WISA speakers and Wifi networks. Has this been resolved? My wireless router is about 6 feet from my BV (there's a wall between them), and I can't really move it. One of the "solutions" to the interference problem was to disable 5GHz which really isn't an option in my home. On the plus side, I don't live in a dense area so there's a lot of open spectrum when I do a wifi scan.
Also does the Receiver 1 have a "wall wart" power supply or does it use a normal plug? I can't see any pictures.
I'm a little gun shy given the poor performance of the BeoLink Wireless 1. If these speakers do not operate reliably, I'll catch a lot of crap from the family...
Thanks in advance,
Seems wifi band crowding and interference will always be an issue no matter what band. I'm fortunate enough I can't even see my neighbors wifi hubs, occasionally one will peak and show up and immediately disappear. Instead of moving everything away from 5 GHz I went to 5 GHz from 2.4 in an attempt to get my Beolink Wirelss setups to work reliably. They were mostly reliable until I got a new alarm system with wireless sensors but that seems to stomp on them so I had to abandon them.
Wisa still intrigues me so it's good to hear it's pretty stable. It would solve some issues with going to Beolabs for my surrounds.
Jeff
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Thanks for the feedback. This all sounds promising, and the chart is helpful as my wifi scanner shows no activity around or near channels 120-128 (I'm in the us).
mbolo01 mentioned above that it's bad to be "too close". Do you have an approximate range for what "too close" is? Also, it's unfortunate the transformer is so large, but oh well...
Next step I believe will be to temporarily hardwire my speakers to see if I like the sound (and wife can accept the looks). 4 rj to powerlink converter cables are much cheaper than 4 receiver 1s.
I have been using speakers with WISA for several years now, never had any issue. There was one time the BL18 went red but then it went green again.
The BL18s are front left and right, are 1m from the Avant and there is a wireless router point behind the TV (i have 3 mesh boxes, that is one of them), albeit the Avant is ethernet to my router (in another room).
The BL3's are rears with receiver 1's and they have never had a connection issue.
I have been thinking of wiring / cabling the 18s to the Avant only to test if there is any sound difference, but wont run cables to the back of the room.
From all of the discussions over the years on this Forum i have read about the BeoLink Wireless 1, this product is nothing like that at all. I think for a lot of products using earlier wireless technologies, it was still fledgling.
Anyway, in summary: it's good, no issues.
Stan:mbolo01 mentioned above that it's bad to be "too close". Do you have an approximate range for what "too close" is? Also, it's unfortunate the transformer is so large, but oh well...
Stan:Thanks for the feedback. This all sounds promising, and the chart is helpful as my wifi scanner shows no activity around or near channels 120-128 (I'm in the us)
mbolo01:I don’t think that 120-128 DFS channels are allowed in the US according to the chart.
You are correct. I read the chart wrong. Thanks again, this is all very helpful.
