Hello Everyone!
I’m helping a mate to fix his beocenter 9500.
Can I reset the system with a Beo 4 or do I need the beolink 1000?
Cheers!
Mike
Welcome to Beoworld!
I had a quick search of the forum last night and found a thread where someone said that both Beo4 and BL1000 can reset the BC9500, but I can't find it again! I used a BL1000 when I reset mine after a battery change.
BTW, I presume that you mean the CoDE reset after a battery change etc? There's lots of advice about this on the forum, and I think you need to remember to press PLAY after entering the digits 1271.
The advice here misses out the pressing of PLAY: https://www.beoworld.org/faq_view.asp?id=76
