Dealers could apparently change the region coding to multi-region permanently. Anyone know how to do this?
Thanks.
I have a 'Magic Beo4' which can multi region the Avant DVD !! I think it came from the B&O factory, but not sure. It works.. I've tried it.
I do remember the Keymaster though, but never saw a DVD1 converted.
Lee
Same question twice in a day - I already replied here: https://archivedforum2.beoworld.org/forums/p/43158/313286.aspx#313286
And as I said I purchased a DVD1 KeyMaster kit (for 99p!) on eBay a couple of years back. It's buried in one of many boxes I think!
Hi Lee,
It would be great if you could post any further info. that you might have regarding this 'Beo4', e.g serial numbers, how did you come by it etc., even the procedure of how it is used to convert DVD to multiregion would be part of the puzzle. If anybody has one of these that works with instructions I would be interested to buy it if they no longer need it.
Cheers,
Duncan.
