Beolab 4000 pulsing tone…
This post has 5 Replies | 0 Followers
matador43
Posts 1,373
matador43 Posted: Tue, Jul 21 2020 3:58 PM
Hi Guys,
I came across a (one) Beolab 4000 for 10€. Sold as faulty.
It's black and in perfect cosmetic condition.
Believing chances were that a good cleaning from foam rot and maybe some tracks to jump will make her alive, I did go get her only to find it's a mark 2. I took her anyway…
The speaker don't turn green, stay red and emits a pulsing sound from the speakers when turned on (feed by music).
I've searched th forum for similar symptoms but without luck. Could someone tell me if it rings any bell?
I know common faults are Stby power unit and/or Ice power amp. Is any of those related with the pulsing sound, or did somebody see a chance to repair it?
I've opened the unit but have not seen anything suspect inside, not even dust.
Any advice welcome.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jul 21 2020 4:53 PM
Hybrid or ICEpower version?
matador43
Posts 1,373
matador43 replied on Tue, Jul 21 2020 5:00 PM
Oh sh***, I believed MK2 were all Icepower.
Can't say for sure but when I opened it I saw PCB behind the tweeter with the 8 little IC that I've already seen in Marexy's BL4 thread.
Serial is: 20657143
Type is 6642.
Dillen
Posts 13,191
Dillen replied on Wed, Jul 22 2020 10:30 AM
Most likely a bad ICEpower module, then.
matador43
Posts 1,373
matador43 replied on Wed, Jul 22 2020 10:39 AM
Bad luck then,
Makes me think the MK1 problems that can be cured with just a good cleaning are close to lovely :-)
Thank you.
Dillen
Posts 13,191
Dillen replied on Wed, Jul 22 2020 12:02 PM
Well.. a cleaning isn't always enough. There's usually a handful of components affected by the dissolving foam material, but most are indeed repairable.
Page 1 of 1 (6 items) | RSS
