Hello BW,
BS 3000 can't start.
Status : glass door can open. CD can load.
Green and Red light are both active on front.
CD & Radio will not start !
Not asking for PIN code in display...
What to do or test ???
Eclipse 65V1-32Beosound M5Essence MK2BLI
What Seanie said. But if the unit don't work from the keyboard, The symptoms you experience are those of a fried unit. I don't know if it is the EEprom or the microcomputer, but its an internal component who tends to fry sometimes. I have one like that and there's some other reports of that on the forum.
As far as i know it's an expensive repair if even still available and without DIY solution.
I hope i'm wrong.
allmost shure is a PCB 6 processor failure
Yes. It is getting old :D
No musik :-(
CD and Radio is not starting when pressing on the BS 3000.
I can get into the TM with the 0258. Do you think I can reset or do other to make change to active system again ?
The red and green led are both on...
Can I see something in one of the TM menu ???
Browsing the TM you should see something like IC error or something, can't remember well. But something you could understand as microprocessor or EEprom error. Then nothing you can do appart from using it for parts, I'm afraid.
I looked at this : https://www.manualslib.com/manual/970884/Bang-And-Olufsen-Beosound-3000-2671.html?page=49
28 MEM +++
27 MEM OK
ML OK
IIC OK
SER OK
CD OK
OS OK
IO OK
AP OK
1 IOP 19
CLR ERR? = CLEARED
34 : OPTION 1
JNielsen:1 IOP 19
IOP: Last error in the I/O microprocessor = 19: TP module HW error APOS
Can't help much more but it seems to be an hardware error. Don't know what TP and APOS are.
I fixed a broken rubber elastic for the LOAD of CD. It works again to load the CD.
Can that be the hardware problem that need to be reset ?
