Dear Everyone,
I have a Beovision 7-32 MKII - I have tried to connect chromecast with HDMI to DVI-I. Picture is perfect, but as many of you may know, with no sound to the beo 7.2 speaker.
I got a tip from a person who are using HDMI to YPbPR on a BV7 MKII and this works perfect with sound and picture. unfortunately, he dosent know how it's works since a B&O technicial did it.
Now i have bought a HDMI to YPbPR converter. (Same as link)
https://www.av-cables.dk/vga-converter/delock-av-multi-converter-til-hdmi-composite-component-phono-vga.html?gclid=Cj0KCQjwvIT5BRCqARIsAAwwD-T8DuX093Yv8QmNPVtUn0jFEjQ86jOu92TYHhIKNmA70k5tx8EWmRgaArREEALw_wcB
But i got no picture - I've tried with setting to choose HD-TV to yes YPbPR at D-TV. Is it something with settings or what can i do to make this work.
Look forward to hear from all experts.
Thank you in advance!!
jesperhj: Now i have bought a HDMI to YPbPR converter. (Same as link) https://www.av-cables.dk/vga-converter/delock-av-multi-converter-til-hdmi-composite-component-phono-vga.html?gclid=Cj0KCQjwvIT5BRCqARIsAAwwD-T8DuX093Yv8QmNPVtUn0jFEjQ86jOu92TYHhIKNmA70k5tx8EWmRgaArREEALw_wcB
Hello, I think you bought The wrong converter!
What you need is a converter with HDMI in and YBPBR and Audio out!
I have the same configuration and I use a HDMI to DVI converter with audio out ,everything is OK!
wilfried
jesperhj: Dear Everyone, I have a Beovision 7-32 MKII - I have tried to connect chromecast with HDMI to DVI-I……....
I have an Apple TV 4th generation.
I have already posted the settings in BV7 in this forum, in this tread:
https://archivedforum2.beoworld.org/forums/p/38866/295361.aspx#295361
I still had my FirevTv stick on the BV7, the Apple TV Gen4 runs with the same settings!
I suspect that the chromecast will also run with these settings.
Over the years the mystery of B&O 7-32 connections Roku 2720 worked for me ,👍 old device I do not think you can buy it now perhaps second hand still a viable?🤷♂️
