Hi
Normal 0 false false false EN-GB X-NONE X-NONE
I'm trying to find the rear hinge part for a BeoGram 6002/8000/8002 (and probably others) series lid i.e. the piece that has four clips/lugs that hold the lid onto the chassis. I don't really need the whole lid just the hinge; as I’m sure some will know the back part and dust cover can be separated by removing the long thin pin that keeps them together to form the hinge. To help clarify the part I'm after is numbered 3 in the diagram and has a part number of '3030067 Back part' in the list of mechanical spares in the BeoGram 6002/8000/8002 services manual.
l'm happy to consider whole lids which include the part I need, as long as the clips/lugs are intact, and willing to pay costs involved.
Thanks Tony
York UK
